Power Cable Gauge Calculator?
Do I assume correctly that recommended wire gauge for a power cable depends on its length and the amplifier demands?
Can anyone point me to a calculator or chart for this?
Thanks!
    pitdogg2 Posts: 27,235
    Anything with 12 gauge or higher will be OK. 14 gauge may work fine I personally prefer 12 gauge or higher.
    Clipdat Posts: 13,100
    edited March 2020
    "Nominal 120 Volts AC - 50 ft or Less:
    18 AWG- 10 Amps - 1200 Watts
    16 AWG - 13 Amps - 1560 Watts
    14 AWG - 15 Amps - 1800 Watts"
  • Gardenstater
    Gardenstater Posts: 4,801
    edited March 2020
    There's a calculator here that gives you the effective damping factor for various inputs, including speaker impedance, amplifier damping factor at that impedance, amplifier power output, speaker cable gauge and length etc..
    http://www.bcae1.com/dampfact.htm
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • BlueFox
    BlueFox Posts: 15,250
    The bigger the power cable the better. Better to have too much versus too little.
  • Gardenstater
    Oh sorry. I misread the post and was thinking speaker cables.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    txcoastal1 Posts: 13,519
    Well your dwelling is likely ran in 12-14awg wiring
    I like to at least match that awg to my amps
