BENQ 8700+ will be in the house soon
goingganzo
goingganzo Posts: 2,793
edited June 2004 in Electronics
well peeps i just ordered a 8700+ on friday i was goig to ge a ae500 but i just got the bug to get a better pj that i will have to tweak a bit less to look great. plus i demoed a clone of it and i have no problems with dlp.
i guess i will have a big screen in the bed room if i dont get it sold.
Post edited by goingganzo on
  • wallstreet
    wallstreet Posts: 1,405
    edited May 2004
    Very nice upgrade. You've got one of the best dlp pj's on the market. But at $7995 MSRP, this one's a long way off for mere mortals. :(
  • goingganzo
    edited May 2004
    actuley got mine for 4k out the door had to haggle a bit but it was all worth it. it will be here tomarrow i might take some time off to make sure i get it.
  • goingganzo
    edited May 2004
    man this thing is awsome at very cloe you can bareley see any sde and this thinf is brite i will be painting the walls a dark color.
  • goingganzo
    edited May 2004
    well i moved the tv ans mocked up the screen i need to get the celing mount to go bigger than 70 in the couch is in the way on the floor
  • goingganzo
    edited May 2004
    and here is a pic of the pj on its box it came with every cable a dvi a rgbhv a vga to dvi a s vid a vid and a pb,pr,y cable
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited May 2004
    Great choice in DLP.
    Use DVi if possible. If not use the best CV cable you can afford. I recommend a Canare or Belden based cable, especially if you will be watching any HDTV (this has the highest frequencies - up to 35 MHz).
    Please post some screen shots in high res on your website, if possible.
    Doc
    SVS
  • scottvamp
    scottvamp Posts: 3,277
    edited May 2004
    Congrats - great looking unit. Your going to love that FP. If you need help or have any questions just ask away. Running FP's for 5 years now.
  • goingganzo
    edited May 2004
    well we are getting voom on the 8th so i just might have to get a dvd player with dvi and a 4 port dvi switcher so i can hook up my comp too. i did have a small problem at first the pic was unstable i found out the hard way the compont ins dont like progresive scan. i will be running a comp cable for my x box, game cube and dvd till i get the wwitcher and all the cables i was going to eather buy one from frank at svs or buy the tools and buld one my self proabley just buy. i still need to get a celing mount.
  • scottvamp
    edited May 2004
    I custom built my ceiling mount. My dad is a weilder fabracater. I design, he builds. Ya, DVI may be the way to go and with HDDVD on the way the new FP's should look amazing. I paid $300 for my 18' component cable. IT worked pretty well. Never got a chance to see HD on my FP. I have DirectTV HD now. Waiting for more HD channels to be added. They look awesome.
  • goingganzo
    edited June 2004
    ok guys here is a update on the pj and install i got the pj mounted to a shelf i atached to the drywall covering the box beam with some brackes that can hold 200 lbs a piece and 4 good drywall anchors but i have to move the pj up 2 in and to the right 3 sence i centered on the pj and not the lense and i have to cut a bit off the brcket to move them up 2 in. and i need to buld a suround for the screen.
    i have about 30 good hours on the pj in svidio and 3 with dvi. and used both dvi and s vid for hi def cable and dvd there is a noticible differance between s vid and dvi but i am waiting to make my cables for the x box and gc and i ordered a dvi switch and 30 foot dvi
    sde is not visible after 10-12 feet and i have to get usto the screen size and the distance i sit at with my lasy eye i have to use both eyes to foucs and i am not usto that. but it will be good si i can maybe i can see 3d imiges on it.
    also the pj is so brite that i am going to paint my walls a dark color a real dark color. i will get some pics when the digital is in the house. total spent will be around 5k after dvi cable/switcher and new componet cable. but not bad for a 115 screen
  • goingganzo
    edited June 2004
    here is the projector mounted
  • goingganzo
    edited June 2004
    and 1 more i will have to get some hi res pic up on my site for you.
