FS: Parasound A21 and Bryston 4B3 Power Amplifiers
Up for sale are 2 amplifiers I am no longer using due to recent upgrades.
Parasound A21 (Black)
9/10 condition purchased from an authorized dealer in December of 2016. Used in both a 2 channel setup for a couple years and then for the L/R channels of my HT setup. There are no cosmetic flaws that I could find and it functions perfectly.
Asking $1500 plus shipping/fees
Bryston 4B3(Black)
8/10 condition (see description below)
While taking pictures I found 3 different 1mm indentations: left top edge of front panel and 2 around the front left top plate screw. The anodized coating in these locations is intact so it may have been a manufacture flaw (see last picture).
I am the second owner of this amp and I purchased it from the original owner in 2017.
It has functioned flawlessly since purchase and I have used it to drive my previous speakers: GoldenEar Triton Ones and also my current speakers: GoldenEar Triton Reference. The amp is the 17" version without handles and the LEDs are green but can be changed to blue with an internal jumper change on one of the PCBs.
The only issue is that I did not know about the Bryston warranty policy requiring the original sales receipt. As such I do not have it and was not ably to obtain it from the original seller.
Asking $3500 plus shipping/fees
Here are some pictures. More available upon request.
Parasound A21
Bryston 4B3
Parasound A21 Specs:
Continuous power output:
250 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, all channels driven
400 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, all channels driven
750 watts RMS x 1, 20 Hz - 20 kHz, 8 Ω Current capacity:
60 amperes peak per channel Power bandwidth:
5 Hz - 100 kHz, +0/-3 dB at 1 watt Total harmonic distortion:
< 0.2 % at full power
IM distortion: balanced 16 V rms
< 0.04 % Slew rate:
> 130 V/µsecond Dynamic headroom:
> 1.5 dB Interchannel crosstalk:
> 80 dB at 1 kHz;
> 63 dB at 20 kHz Input sensitivity:
1 V for 28.28 V, THX Reference Level
Input impedance:
33 k Ω unbalanced; 66 k Ω balanced S/N ratio:
112 dB, input shorted, IHF A-weighted Damping factor:
> 1100 at 20 Hz Voltage:
110V - 120V Dimensions:
17-1/2" w x 7-5/8" h x 20" d, 7" h without feet Net weight: 60 lb.
Bryston 4B3 Specs:
Power output: 300 watts per channel at 8 ohms; 500 watts at 4 ohms; bridged mono 900 watts per channel at 8 ohms
Gain: High 29 dB at 28.28 V/V; Low 23 dB at 14.14 V/V
Sensitivity: High: 1.0V, 100W; High: 1.7V, 300W; Low: 2.0V, 100W; Low: 3.5V, 300W
Input Impedance, Individual Mode: Single Ended ≈60k ohm; Balanced + ≈60k ohm; Balanced - ≈12.5k ohm;
Input Impedance, Bridged Mode: Single Ended ≈10k ohm; Balanced + ≈10k ohm; Balanced - ≈10k ohm;
IMD: ≤0.005%, Typ. ≤0.002%
Noise (input shorted 20Hz to 20kHz): High: 29 dB, <0110dB (-75 dBu); Low: 23 dB, <0113dB (-78 dBu)
Damping: 20 Hz, 8 Ohms, >500
Power consumption (watts): Standby: <0.5; Idle: ≤70; 2Ch. 35W 8 ohm: 550; 2 Ch. 300W 8 ohm: 1000; Bridged: 900W 8 ohm: 1700
Dimensions: 17" or 19" wide, 6.3" high, 16.2" deep (add 1.6" depth to C-Series 19"-wide model for front-mounted handles)
Weight: 63 lbs.
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G
  • steveinaz
    steveinaz Posts: 19,546
    That's an excellent deal on that Parasound.
  • sgmsmg
    sgmsmg Posts: 556
    Forgot to list my location. These amps are located in Beaverton, Oregon 97003.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Clipdat Posts: 13,100
    Do you have original box for the Bryston?
  • sgmsmg
    sgmsmg Posts: 556
    Yes I have the original box/packing materials for both amps. The Bryston only comes with a single box but the Parasound has a double box. I can try to find another box for the Bryston to add another layer of protection.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
  • Willow
    Willow Posts: 11,284
    Dems er nice amps. GLWTS
  • gyosa
    gyosa Posts: 770
    edited March 2020
    I can vouch for how Stellar the A21 is .....
    GLWTS ...
    Bk
    Post edited by gyosa on
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • sgmsmg
    sgmsmg Posts: 556
    If anyone is interested in either of these reach out to me and maybe we can make a deal. I will probably be consigning them in the next couple of days.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    gudnoyez Posts: 8,174
    Parasound packs them good my A31 shipped in its factory double box from Adio Advisor. I wish I needed a A21 great amp priced nicely good luck with the sale of both those amps.
  • steveinaz
    Can't believe no one has grabbed that A21.
  • BinKY188_5
    BinKY188_5 Posts: 144
    Would that A21 be a good match for SDA SRS? Common Ground?
  • oldrocker
    oldrocker Posts: 2,590
    Very good amp, excellent price for all that power.
  • gyosa
    gyosa Posts: 770
    He!! Yeah !!
    I’m using one with 1c’s ......
    Plenty of current .....
    Seriously, it really is a great amp ...
    When I’m in need of another amp - I’ll be buying another one ....
    Bk
    BinKY188_5 wrote: »
  • sgmsmg
    sgmsmg Posts: 556
    The Parasound A21 has been sold to Mike Reeter
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
  • teekay0007
    teekay0007 Posts: 2,288
    Nice get, Mike!
    Congrats guys!
  • BinKY188_5
    Thanks Mike for keeping me from spending money that I really shouldn't. Congrats on the purchase.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Just wanted to note that I received the A21 today from Patrick. The Amp is EXACTLY as described, if not better.
    He promptly shipped it immediately after we came to terms, and it arrived in Pristine Condition.
    If anyone is remotely interested in the Bryston that Patrick has for sale, I recommend reaching out to him. I can vouch for the man with utmost confidence.
  • sgmsmg
    sgmsmg Posts: 556
    Thanks for the praise Mike! Glad you are happy! Enjoy!
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Pre: Anthem AVM90
    Amps: Buckeye NC502
  • verb
    verb Posts: 10,176
    Oh dear. :smile:
    There is an A21 near me. 33k ohm input impedance. And gain adjustment knobs on the back. Should play nice with my Joule! :smile: Oh dear.
    https://www.usaudiomart.com/details/649602804-parasound-a21/
  • jumpindick
    jumpindick Posts: 428
    verb wrote: »
    Oh dear. :smile:
    Looks in great shape as well. Wouldn't go wrong with it at all, IMO.
  • Mike Reeter
    verb wrote: »
    Oh dear. :smile:
    Dave, My new A21 is telling me what my SDA's are capable of. I've been reading on this Forum for years about how good a matchup the A21 and SDA's are. Everyone has been RIGHT.
    I can't imagine that you would be sorry.
  • gyosa
    gyosa Posts: 770
    I’m using an A21 with my 1c’s ....
    I likey
    Bk
  • Dr_Wu
    Dr_Wu Posts: 356
    CRS-SDA+4.1TL loves the A21. If I'm not mistaken, Skip and Audio Advisor still have some of these NIB at a nice price.
  • verb
    verb Posts: 10,176
    verb wrote: »
    Oh dear. :smile:
    I need another amp like a hole in my head. Wait, yes I do need another amp, to match the hole in my head! :smile:
    Aw man, Michigan is locked down for non-essential travel. Wait, this could be essential.
    Aw man, but the Mrs is home all day long now. Foiled again! :smile:
