Subwoofer popping
pete66
MagniFi max system 6 weeks old and beat buy won’t take it back.
Subwoofer started popping at any volume at random. Tried turning bass down and up. No change
I have read on many other forums this is an issue with software, maybe internet connection. I’ve tried everything including putting it temporarily in the office with the WiFi box. Nothing makes it stop popping.
Does not do it while running sound from the dish network broadcast, only while using music or streaming video content.
Anybody successfully fixed this?
I forget the software version now but two weeks ago it was current and I have it set to update as needed.
Typically characteristic of voice curl consumes at explicit regions. Any more appeal in that recurrence bringing about splitting as it fundamentally shorts out the loop.
Samsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
BJC 10 ga - LCR mids “Foamed & Plugged**”, inside* & out
*all connected w/Premiere ICs
