Need to change out a stuck tweeter rt 2000
Flegg
Flegg Posts: 8
Hi there
Im changing out a blown tweeter in a tower speaker rt 2000. Its my first time attempting this but it seems stuck in there and removing it i would need to pry it out. I dont want to this in case i damage it. Is there another way of removing the tweeter and replacing it.
Best Answer
  • codycatalist
    codycatalist Posts: 2,661
    Answer ✓
    VR3 wrote: »
    It's a very nice thumb in that video if I do say so myself
    The best one I have seen thus far, makes mine look inadequate.
Answers
    F1nut Posts: 52,164
    I take it you removed the large plastic bezel around the tweeter and driver, right? If so, you will find it easier to remove the driver first, then reach inside to push the tweeter out.
    Tony M Posts: 11,869
  • codycatalist
    Tony M wrote: »
    From our very own VR3
    VR3 Posts: 29,631
  • Flegg
    Flegg Posts: 8
    Thank you guys that worked. 👍👍👍👍😁
