RX-V2400 no OSD at 1080i only 480i??
CBrischler
My Yamaha RX-V2400 will not put out On Screen Display when using 1080i as in HD TV... Yamaha said this is correct and will only work in 480i. This seems like a pretty big oops if you ask me as everything will be going to HD shortly. Yamaha says there is no way around this... anyone have any thoughts on a solution and why this is occuring?
Buzz
Buzz
Post edited by CBrischler on
So youre excited about your HDTV.
Yamahas reason is compatibility. 99% of the current TVs will accept the RCA input {480}.
You would think Yamaha could do a bit more on the graphics on the OSD.
They remind me of the Atari 2600 days.
:rolleyes:Front: LSI7
Center: LSIC
Surrounds: LSI7
SVS PB2-ISD SUB [MONOLITH!]
ATI 1805 Amp
