Latest Cambridge Audio Update
audioluvr
So on Feb 28th, CA released their latest firmware update. Immediately following that my 851N would not recognize my laptop and needless to say I kinda freaked out as this is the main way I navigate what I listen to and the last update shut down my streamers bluetooth feature (which I sent a nasty email regarding this). Sent another nasty email to CA customer service and their response was "Did you do a factory reset like we asked you to do last time???" Uh no. So I wrote down my presets so I could easily reprogram them and went into settings. At the very bottom of the list is "factory reset".
Once the reset was done I had to redo the wifi link. Plugged in my laptop and immediately the 851N shows something I've never seen before "USB Audio 96.0kHz" Used to only show 48kHz unless I was playing a "master" file on Tidal. YES!!!
Any owners of these streamers who've had updates might want to try this if you're having any issues.
R
R
Have not done the update yet. Thanks for the heads up!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Did the update couple days ago ....
Didn’t notice any major changes ....but I only stream via a wired ethernet connection.
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
