High gloss black repair
So I scored, a literal brand new in the box, never been used pair of definitive tech power monitors (speakers are 20 years old!) ... Somehow though there are two marks on one of the caps, not so much as swirl marks elsewhere, literally brand new still in the packaging.
Anyways, anyone know of someone who can restore this to new??
Body shop...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Hard to tell, are those chips?
The finish is likely either car paint or polyester. Hopefully, Def Tech can tell you which. If car paint a body shop is in order. If polyester a piano repair shop should be able to repair it.Political Correctness'.........defined
President of Club Polk -
They have always advertised it as a piano gloss black lacquer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That means it's polyester.Political Correctness'.........defined
A Sharpie?
It will be difficult to fix this at home without leaving a trace. Even if you get the exact paint you will then have to sand it with the right grit sandpaper and then use the right polish. Even then it will never be perfect. You could get 90% there with a gloss black car "touchup" paint. It looks like a bottle of nailpolish and you can find it in any car parts store. Use thin coats and fill in the chips. It might be a little raised when you are finished but I would avoid trying to sand it unless you are a professional. -
Yeah I may end up using the sharpie, but I am just disappointed as they were advertised as new and they had the blemish, was just excited.
May take it by an auto body shop at some point
Thanks guys- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Lacquer is very easy to spray. You might not be able to match it completely, but could probably get close. You wet sand lacquer and then buff it out.
If you don't want to do that, then take it by a body shop like you said and see what they say.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
It's not lacquer, it's not car paint. It is polyester.Political Correctness'.........defined
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Trey, any chance they have any backstock of the tops? Long shot given the age, but you never know lol....
I think Polk has a pair of SRT's still in their deep freeze and those are just as old lol...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Did you try some black spray paint? If you can find it?My New Year's resolution is 3840 × 2160
I did call definitive and unfortunately not! I had hope
Get a bottle of modeling paint and a super fine tip brush.Gustard X26 Pro DAC
I used to repair chips like that for new home construction.
I repaired bathtubs and even though most are almond or white, black porcelain tubs and tiles were not unusual.
Call a bathtub repair shop and tell them what you have and they might come out and do the repair on the spot.
Depending upon where the chip is it may always be seen if light shines directly onto your repair.
Primaluna Dialogue Premium Tube Amp
Polk Audio LSiM705
Marantz 6006 cdp... 500gb flash drive
Audiolab m-dac
Analysis Plus Oval 9 Speaker Cable
Analysis Plus Oval One I/C's -
To further that comment above, the process used to touch that up is called “burn in”
We do that here in Atl
The trick for that is to find the putty to match and a clear coat that will blend.
The process :
https://m.youtube.com/watch?v=hDWzPA3ceC4 -
Great video
All are techs carried mohawk repair kits for cabinet repairs simular to that
We basically did auto body repair on bathtubs
Personally I would have filled it and spray the one panel to make it a uniform color or at least blend it out with airbrush
Cool thing you have going in Atlanta
Polk Audio LSiM705
Audiolab m-dac
Actually,
you could just face it with a veneer panel that would be cut to fit and already high gloss black or color match it to correct sheen
Make sure it fits and looks good before you apply the veneer
Cheap and easyPrimaluna Dialogue Premium Tube Amp
Polk Audio LSiM705
Audiolab m-dac
In guitar repair, I used to color a chip in with an appropriate colored sharpie and lay a drop of krazyglue over it until it was built up slightly higher that the surface.
Then I'd take a one sided razor blade and put a piece of scotch tape over each side of the sharp edge, leaving a gap in between.
Keeping the blade upright, I'd gently back drag the untaped edge over the glued area until it was level with the finish around the repair.
After that it was lots of sanding with emery paper, then 0000 steel wool and ultimately some Maguires auto buffing compounds.
To get the final gloss, I'd use Simi-Chrome motorcycle polish.
It's not a job for the squeamish, but done correctly works quite well.
There's youtube videos by a repairman named Mark Erliwine on the subject.
