What make/model Portable Handheld Audio Recorder do most of the Audio guys use?
Alton T
Alton T Posts: 73
edited February 2020 in Technical/Setup
Hello Forum,
I see many reviewers using , what seems to be the same Portable Audio Recorder.
May I please ask,
What is the company and model number?
Also, what software program are they using?
What is the proper name of that software that displays the Frequency /Db graphs
and other features/functions?
Yes, I am ignorant.
I try to do searches, but, I am ignorant when it comes to the proper terms/names to type in..
"Ignorance is not a bad word, but, it does cause a lot of Problems" - Alton Takata
Thanks for viewing..
Alton T :)
Best Answer
  • Alton T
    Alton T Posts: 73
    edited February 2020 Answer ✓
    Hello Forum,
    That Portable Recorder is a Zoom H5
    I thought it was a TASCAM ..
    That photo is from seas- lyd's YOU TUBE video.
    I saw the name "Zoom" printed on the recorder in a video he just posted this morning.
    I enjoy seeing his new post of what he has next..
    Thanks for viewing.... :)
Answers
    mhardy6647 Posts: 35,354
    with the long play adaptation...
    12542868135_def797f0f2_z.jpgstella by Mark Hardy, on Flickr
    I mean, the Nagras are nice, too -- but the really cool kids use Stellavoxes.
  • That is awesome possum !!
  • Alton T
    Alton T Posts: 73
    Hello Guys.. :)
    Here is the screen shots of the first Pink Noise test results.
    I did not set the Volume, so, was a bit loud.
    UMIK-01 MiniDSP Microphone at 40 inch height ( Tweeter level) , where I sit.
    Room is 10 x 15.
    I sit about 4 feet from the back wall.
    Polk A9s about 4 feet from the back wall. 5 feet apart.
    I listen to a Jazz Trio ( Double Bass, Piano,Drums) and set the tone controls to the "Best" settings I heard.
    Then, I do the Pink Noise Test.
    DB is 87 ..
    I am not sure if this is good stats, but, seems level?
    Low frequency is loud, but, that is only those deep Double Bass notes.
    and the Highs are crisp and not "piercing".
    If not the volume level being loud. Seems good, but, is this good ?
    Alton T.. :)
  • BlueFox
    BlueFox Posts: 15,250
    What are trying to accomplish? What are you talking about?
  • I think this belongs to the other post I made.
    I moved this over. Sorry Guys..
