B&K ST 3030 200 w/ch power amp MOS FET
geppy1
Selling my B&K ST 3030 power amp. I do not need two B&K amps so this is being sold. It is in overall excellent condition with the exception of one small discoloration/mark on the front panel. The amp works perfectly works as it should. The 3030 puts out 200 watts per channel into 8 ohms and 300 into 4 ohms with 42 amps of current capability. it is built like a tank and weighs 39lbs. It has a RCA and balanced inputs. . The feet have been up graded and I am including a better 14 GA power cord. Power Switch, and Balanced Switch were properly cleaned with Deoxit D5n and G5n to ensure a good contact. The RCA Jacks were also cleaned with Deoxit and a Q-Tip to remove any oxidation on the contact points. The sound is musical and smooth slightly warm with good detail and a sense of dimension so many amps are missing miss. I have had many amps and I still think B&K is the best bang for the buck Asking $350 Thanks
Smoking deal here folks!
Does this amp have common ground?
I have used B&K amps with SDAs with no issues but only 1c,2B and 2A . I believe it is common ground but maybe someone else knows for sure Thanks
POLK PRICE Now $320 -
it is common ground
someone better step up and buy this before Verb does to power his coffee maker.
I thought I had a pretty good price set on it
Smoking good deal here!Gustard X26 Pro DAC
PRICE NOW $295!!!!
Wow - hard to better this (200 WPC, balanced inputs) at even 500! Great deal here folks - why is this still here?
BUMP
SOLD elsewhere
