40 days and 40 nights and my cxn v2 don't see my NAS anymore
I don't know what changed but my Cambridge streamer just says "empty" when I try to play the files on my NAS. It still plays files from my Auralic Mini (streamer to streamer) and all my PC's will play files from the NAS. What gives, any ideas?
    treitz3 Posts: 20,119
    Sure. Buy physical media.
  • afterburnt
    afterburnt Posts: 7,892
    I got another question, did you ever drop a deuce so putrid and foul that you slapped yourself for doing it? Asking for a friend.
  • afterburnt
    treitz3 wrote: »
    I do then I rip it and then it goes into long term storage.
    To answer your question seriously, I don't know. Have you tried a hard reset?
  • afterburnt
    I forced a rescan but not a reset. Wouldn't a hard reset wipe it?
    Hard reset as in power it down, unplug the PC. Wait about 30 seconds, short out the hot and negative pins on the PC and reboot.
  • rooftop59
    rooftop59 Posts: 8,120
    afterburnt wrote: »
    What Tom is suggesting should not reset it. But after the hard reset, the next option is to restore factory settings and start over...better than it not working!
    Game Room 5.1.4:
    Bedroom 2.1
  • verb
    verb Posts: 10,176
    @Clipdat any suggestions Drew?
    txcoastal1 Posts: 13,519
    Does your NAS have a static ip?
    If on DHCP has the IP changed
  • afterburnt
    Resest did not help.
    I am looking for the ip settings, any ideas?
    Clipdat Posts: 13,100
    verb wrote: »
    Contact Cambridge support, they have excellent customer service in my experience.
