Best Spl Sub
Systems
Whats the Best Spl Sub for under 500$?
Testing
Testing
Testing
Testing
Testing
resonance engineering ****
Actually...there is no such thing as "the best of anything"...
but RExxx is definatly one of the Better subs
along with Digital designs -
yeah...the 9915 is comparable to the **** from Digital DesignsOriginally posted by TrappedUnder Ice
i think its the 9915...
9915 is a lot more than 5 bills.
i think the idmax in a 0.9 cubic foot box with 2,000 rms on it will do as well or better than just about anything else at or below 500 bucks for SPL.The Artist formerly known as PoweredByDodge -
Nada, you put a **** up to a max sealed in SPL, the max will lose. If you went ported with the max it will be decently close, but the **** will have more output.
18" **** IMO is the best SQL sub for under 500$
A solo-X is louder, but over the limit.
A used DD 9515 or 9915 would be your best bet. Look on ebay for them.Testing
Testing
Testing -
he meant amp included
ID Maxes are no where near $500
For spl only I would choose the RE SX or RE MT over the ****. They both are more built for spl. The **** is built more towards sq that can get pretty loud.
later,
james -
Actually I change my vote to the brahma or SX........the SX can take 5k burps with ease.Testing
Testing
Testing -
theres a brahma that will kill both of those subs with ease...i forgot what it was called...you have to special order it though...
You talking about the Adire Parthenon? The $5000 sub?http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
thats the oneMusic is like candy, you have to get rid of the rappers to enjoy it
for burps... this guy has 2 MA Audio 18 XE(about 200$ or less each are taking over 12,000 wats...rms
http://www.termpro.com/asp/competitorstats.asp?competitor_ID=26033
- Slain -
you can get an RE MT for under 500, and they are made for spl.
