Just a thought
presidan
presidan Posts: 116
edited January 2002 in Technical/Setup
I was wondering if it was by any way possible to fit those highly acclaimed ring radiators on the RT2000I's and F/X1000's ??? I'm thinking; probably not but if there is a way to do this i would sure like to know it ?
i know that the 2000's and 1000's tweeters are mounted in some kind of plastic mold with the mids and that the ring radiator tweeters fit directly in the speaker.....I'm thinking that my 2000's would be allmost perfect with those rings in................
I was just wondering
RT2000i
F/X1000
CS400i
DENON AVR-3802
PIONEER PDP 4360-HD 43"
Post edited by presidan on
  • juice21
    juice21 Posts: 1,866
    edited January 2002
    that is an interesting thought, especially since you could order the vifa ring radiator tweeter at PE. this had crossed my mind too, i figured it probably couldn't be done as well. it would be the ultimate tweek if applicable....
    any thoughts from the more technically inclined out there, could this be done?
  • Aaron
    Aaron Posts: 1,853
    edited January 2002
    I highly doubt the tweeter would would work properly with the current crossover.
    Aaron
  • juice21
    edited January 2002
    that's what i was figuring, but i didn't know how much that played a role in it, i know it's harder than just wiring in and custom fitting a new tweeter...;)
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2002
    ...Detailed specs for both tweeters. Especially the SPL or effc rating and impedance. The new Vifa is a 4ohm tweeter, with an SPL of 91.5 db 1w/1m. This is a good match as far as SPL for most Polk speakers, however it may need to be toned down in the xover network to match your woofers/midbass speakers. (ex, if they are running 89db).
    With the low F3 (resonant frequency) of the new Vifa, the actual xover point will be a non-issue, as far as upgrading the RT/RTi line.....
    As far as modifying the cabinets for a 'professional' fit, depends on how good a fabricator you are......
    Thats how I see it anyway.
    Cheers,
    Russ
  • presidan
    presidan Posts: 116
    edited January 2002
    Hmmmmmmm, so it could be done. The thing is that i am not the do it yourself kind of guy...... But, the idea of inserting those ring radiators tweeters in my 2000's sure sounds GREAT. Would there be a way to get a Polk representative or someone to do this without **** up my warranty ? I am willing to give it a try.
    RT2000I SE... that would be real nice
    RT2000i
    F/X1000
    CS400i
    DENON AVR-3802
  • presidan
    presidan Posts: 116
    edited January 2002
    Well, i wrote to Polk about this and here is what they had to say:
    Hello,
    I am sorry but there is no way to replace current tweeters with the ring radiator tweeter. They will not "fit" the cutout and will not be compatible with the crossover.
    Best regards,
    Lauren
    Damn conspiracy, they got me looking at the LSi's now......
    RT2000i
    F/X1000
    CS400i
    DENON AVR-3802
  • ntculenuff
    ntculenuff Posts: 1,146
    edited January 2002
    I too got the same kinda reply back..I asked if I could switch out the tweets in my RT10's to match the tweet in my center channel (cs350ls)..
    I wanted to change out the soft dome for the tri-lams, but no go:(
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
