RTi A7 or RTi A5 - which will work best for my needs?
Hello All, I have a greatroom that measures 20 X 16 and my current setup consists of a 65 inch LG OLED TV, Denon AVR-x3500h, Tannoy Mercury MX bookshelf speakers for Front and Surrounds (5 1/2 inch woofers), a Tannoy Mercury Center Channel (4 inch woofers) and an SVS PB1000 sub. I recently added the Pioneer Atmos speakers that sit on top of the bookshelf fronts. My Tannoy speakers are about 20 years old and they have served me well but I'd like to upgrade them.
I am considering the following:
CSi A6 for the Center
RTi A1 for the Rear Surrounds
RTI A7 or A5 for the Fronts
Will my Denon be able to power the A7 or would the A5's be a better choice? I can't afford to add an amplifier to my setup at this point.
Would the FXi A4 be a better choice for the rear surrounds?
    F1nut Posts: 51,953
    Set the speakers to small, cross to sub at 80Hz and your AVR will be ok driving this package.
    RTI A7 for the Fronts
  • polrbehr
    polrbehr Posts: 2,847
    If funds permit, you may want to consider a second PB1000 sub too.
    Just my .02 helping a new member empty their wallet.... ;);)
    F1nut Posts: 51,953
    polrbehr wrote: »
    You're always so thoughtful Harry. B)
  • Thanks All,
    I ended up going with:
    FXi A4 for the Rear Surrounds
    RTI A5 for the Fronts
  • rooftop59
    rooftop59 Posts: 8,120
    Reyfam123 wrote: »
    Thanks All,
    Did you get it set up yet? How’s it sound? Better than the Tannoys?
    Game Room 5.1.4:
    Bedroom 2.1
