how do i get a discount here
pmpn86celebrity
first off i'm wonderin if polk makes a amp i heard not. i'm wondering wat kind of amp i should get i need a 800 wat amp for 2 12 inch speakers in my car trunk. i want a good one for cheap. also i need a head unit i'm thinking sony explode but thats 239.00 but are they ny good if they are i'll get one and wat kind of speaker should i put in to replace factory i'm thinking infinity gold. and how do i get a discount here can i get a head unit and a amp here.
Post edited by pmpn86celebrity on
for an amp for 400 watts i think us acoustics makes a 1000d amp for pretty cheap on crutchfield
i wouldnt go with sony but whatever floats ur boat -
Go with mm465's in the front and back. Go for Phoenix Gold ZX series amps zx500ti will power both sets of mm465's. Use Brax amps for your subs. Then you'll be set around 400 dollars.Testing
Testing
Testing -
i would go with a alpine head unit they are good and good qualty i have owned 3 so far and i still have all of them in my cars
