Htpc 4k comparability.
So I've got some concerns about parking an htpc. I've got 2 and ryzen builds, with more than enough horsepower to run 4k, an 1800x with a 1070ti, and a 3600 with a 1080. Only problem I see, all the 4k optical drives say they're only compatible with 7th gen Intel or newer, unless you wanna go through some work arounds. I don't want work arounds, or bootlegs, or pirated media. I want to make something that works right. Does anyone know if there's any legit and easy ways to make AMD play nice with 4k BD, or do I need to build an Intel rig for an htpc. I've already got someone interested in buying one of my PC's which would probably fund it. Is 8t worth it? I was probably gonna upgrade my Xbox to a one x anywho, should I just be content with that? I also have a small msi trident PC, running an Intel 8400 and a 1060 3gb. It is an ultra small form factor PC, that doesn't support an internal optical drive, so there may be some sort of work around there. Any suggestions guys?
    EndersShadow Posts: 17,741
    I’d just upgrade the Xbox. It’s a single easy solution.
    I’m in the same boat (just a ORIGINAL Xbox One), just waiting till the next Halo comes out (so I can buy the console I assume they will make to bundle with it).
  • seabeerob213
    seabeerob213 Posts: 1,843
    That's kinda what I've been leaning towards, but I don't care to wait for that bundle, Amazon has some decent bundles at decent deals, and the exchange will price match them.
    Oh I agree, if you don’t want to wait, just grab what you can.
    I’m a bit of a Halo nut, so I never assume others are too lol
  • seabeerob213
    Halo reach was the best online Halo, MC collection was my last Halo purchase, idk, haven't played 5, and was separated from my Xbox for like 6 months mid Halo 4 and never got back into it.
