New bedroom system advice?
CH46E
CH46E Posts: 3,595
edited January 2020 in The Clubhouse
So I need a small form factor setup that I can run a optic out from a TV to to power two or three small speakers. Would like to have the front stage. Left, Center and Right and a small powered sub.
Again needs to be small. Not standard HTR.
Can anyone recommend a piece gear that can do this in a small package?
Something like the size of a Parasound ZAmp?
Chris
  • rooftop59
    rooftop59 Posts: 8,120
    I’m sorry I am not aware of anything that small that is 5.1. Marantz slimline or comparable from Yamaha or Cambridge is the smallest I know of. But I have to ask, is the center channel necessary in the small space? I run 2.1 now on the living room and master bedroom and have not missed the center. Ymmv...If hearing dialogue is the problem, then yes, perhaps a soundbar is the ticket...
    Game Room 5.1.4:
    Bedroom 2.1
  • CH46E
    CH46E Posts: 3,595
    I was trying to avoid a sound bar but I'm ok with it possibly being the only option at this point.
    Thanks guys!
  • Willow
    Willow Posts: 11,285
    Can't help you. Have not had a tv in the bedroom for over 20 yrs.
  • kevhed72
    kevhed72 Posts: 5,172
    rooftop59 wrote: »
    Agree....I have a mini 3.1 Polk RM system in our small TV room and find myself flipping the AVR to stereo quite often.
  • CH46E
    CH46E Posts: 3,595
    So I guess it's going to be a soundbar. It will make a clean install in a difficult spot and I suppose it will sound ok.
    EndersShadow Posts: 17,727
    edited January 2020
    CH46E wrote: »
    We got one from Polk that has a wireless sub. Very respectable... I wrote a review around here somewhere
    pitdogg2 Posts: 27,426
    Yea with all the problems seen here from Polk soundbars it would be my last resort. I have 3 friends who bought from Amazon polk sound bars all 3 DOA and well do we even need to go into any sort of support from Polk CS...ahem I mean Denon support the worst in the nation for going on a close to 20+years.
  • CH46E
    CH46E Posts: 3,595
    edited January 2020
    Good to know guys. Thanks. I may go with Yamaha or JBL.
    A wireless sub would be great.
  • rooftop59
    edited January 2020
    Based on the dealer formerly known as Dskip’s recommendation I have been tempted to get one of these even though I have no use for it lol...
    https://www.accessories4less.com/make-a-store/item/polkmagnifimini/polk-audio-magnifi-mini-ultra-compact-home-theater-sound-bar-system/1.html
    Game Room 5.1.4:
    Bedroom 2.1
    edited January 2020
    Normally I’d agree, however mine is one of the older(ish) ones and We’ve had no issues.
    It doesn’t have lots of fancy options but man does it work.
    Signs S1 I think...
    https://forum.polkaudio.com/discussion/181837/review-polk-signa-s1-soundbar-wireless-sub-combo#latest
  • tratliff
    tratliff Posts: 1,819
    edited January 2020
    Many sound bars could fit. You did not mention budget but as you move up in quality/price you will be surprised at the performance you might see in a solution that could seamlessly fit in. This is what I have done. Works great and have not looked back.
  • BlueFox
    BlueFox Posts: 15,250
    I use a sound bar (Samsung MS650) on my 65” TV in the office room. It actually works pretty good. Now I rarely watch my 75” HT with the surround sound system.
  • deronb1
    deronb1 Posts: 5,021
    There are some Polk Woodbournes still out there. I havent heard a soundbar yet that compares.
  • CH46E
    CH46E Posts: 3,595
    edited January 2020
    It will be a 55 inch tv wall mounted up high and tilted down.
    Budget of about $225.00.
    Chris
