Replacement speaker
JMPerry
Is ther a replacement for a RDO303-2 432TF speaker?. I'm not sure weather to repair these units.
Cheers, John
Cheers, John
I think the driver is supposed to be RD0303-2 (RDzero). Pictures would help. From what I am guessing they are from a RM3000 small satellite and sub system.
https://us.v-cdn.net/5021930/uploads/attachments/4/1/6/7/8/1351.jpg
https://forum.polkaudio.com/discussion/8403/rm3000
Assuming this is the speaker and this is the version with foam surrounds on the driver, you can get replacement surrounds.
https://www.midwestspeakerrepair.com/shop/speaker-repair-kits/refoam-kits-by-brand/polk-audio-1-specialty-refoam-kits/polk-rm-3000-monitor-series-2-3-5-inch-refoam-kit-f3-3/
If you don't want to try refoaming the speaker yourself, I think if you sent the speakers in, midwest will refoam them for you and send them back for an additional fee, or a forum member may be able to help out.
Otherwise drivers or complete speakers can be found on ebay.
