Is there a fuse inside the bar if so how do I get inside I'd it
Help
Answers
    F1nut Posts: 52,136
    edited December 2019
    Try being specific when asking a question. For example, note the brand and model number of the product. Describe exactly what issue you are having and what, if anything you've tried to fix it.
