I'm scared to hook my McIntosh MC2100 to SDA SRS 2 Common Ground Help??
Hi, I just got a great deal on some very nice SDA SRS 2's and I can't wait to try them out. But I'm scared to hook them up, I have no idea if my amp is Common Ground, or how to even check. Does anyone know if I am safe to Rock these baby's with my Vintage McIntosh MC2100? Thank you! John
  • verb
    verb Posts: 10,176
    John312 wrote: »
    Hi John - I have an MC300, which is common ground, no issues. Do you have the interconnect cable? Until you're sure, you can run em without the cable. If no one here can say for sure, reach out to McIntosh technical service, as they are very responsive.
    In the meantime, rock on! :smile:
  • lawdogg
    lawdogg Posts: 470
    edited December 2019
    According to the circuit diagram, the MC2100 is common ground (chassis ground, in fact).
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • sbb2112
    sbb2112 Posts: 134
    Unless you get into the quad balanced amps they make, the stereo amps are fine.
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • John312
    Thanks everyone! Can't wait to hear these puppy's. Would anyone care to let me know why its best to keep them close to the wall? I have been told that 8" ideal?
  • delkal
    delkal Posts: 764
    For a reality check get your Multimeter out and check the resistance between the L and R speaker grounds with everything off. It should be very close to zero. On my multimeter it reads 0.6 ohms (the same value you get when you short the DMM leads together). That means they are connected together internally the amp.
  • verb
    verb Posts: 10,176
    John312 wrote: »
    From the Polk user manual. I have my SRS's about 6" from the back wall. Hope this helps.
    https://polksda.com/
