Spa is now operational
After decades of operation, the pump on the spa started making a really loud noise when it ran. It seemed to work okay, but was so loud I could hear it inside with the doors and windows closed. I finally just powered it off until I got it fixed. Then I ended up in the hospital at the end of October, but am now home and getting my act together. Today the spa technician came out and replaced the motor. Now it is running, and I can’t hear it. Hallelujah.
Once the temp gets to 104 tonight then I will be in it. My body will most definitely appreciate that. :)
  • gyosa
    gyosa Posts: 770
    Pics ?
    Not of you , but of some hot , young nubiles enjoying the warmth .....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • BlueFox
    BlueFox Posts: 15,250
    It’s getting there. Now it is at 80 degrees, so in another two hours it should be ready. That is ideal since neighborhood noise has quieted down by then. So far the night is clear so the outside temperature should drop into the 30s.
  • BlueFox
    Finally, it’s at 104 degrees, and I was in it for close to 30 minutes. Now I am ready for bed, at least after I cool down.
    msg Posts: 10,475
    No selfies.
    Unless flanked by two models.
    (And not airplanes)
