Houston, my SRS 3.1's have a problem.
ThomasR
ThomasR Posts: 14
edited December 2019 in Vintage Speakers
My granddaughter found something interesting to tug on. Unfortunately her curiosity wounded my SRS 3.1TL's. As you can see the speaker post is snapped off.
What's the best way to fix it? Are these a standard item I can buy somewhere? I use all 4 terminals since I have it bi-amped.
    VR3 Posts: 29,612
    Easy fix.
    Replace them all! 😁
    All kinds of brands, wbt, cardas, cheap Chinese ones, Dayton, world's your oyster! Don't even need to know how to solder. Just need plyers, a hot glue gun and patience!
  • That's a relief. I just opened it up and I think even I can do it. I took a quick look online and the prices for these are all over the place. By the looks of it Polk didn't use anything very fancy/expensive
  • verb
    verb Posts: 10,176
    ThomasR wrote: »
    Yep. Maybe since you got the hood open, might be an opportunity to upgrade. Make em grand daugther proof, ya know! :smile:
  • Have you done any upgrades? If not and are curious about what upgraded sdas sound like i got a pair of upgraded 2bs in houston. Granted they r storage in the garage for christmas.... But thats temporary.... Stupid tree going where my equipment goes......
    F1nut Posts: 52,109
    Ouch!
    I'm not actually in Houston. I just borrowed the line from Apollo 13 for dramatic effect. Their problem was probably bigger than mine, plus I can get what I need to fix it delivered.
