In Ceiling Speakers
I'm building a dolby atmos system and going to be installing in ceiling speaker. Im looking at the rc60i's, 4 of them, cant go with the bigger 80i's, and the klipsch cdt 3650 because the woofer and tweeter both are amiable unlike just the tweeter on the rc60i. My concern is timber matching, I'm running the 706c and 2 703's for the center and 2 fronts and fxia for surround. Going to be purchasing the denon 6500 to power everything. Which would be a good 6" in ceiling speaker? Any suggestions is appreciated
Yamaha rx-a2000 AVR
Polk csi5 Center
Polk rt16 Main
Polk fxia6 Rear Surround
Paradigm Micro Rear Back
Onkyo bookshelf Front Presence (for now)
PSW 450 Front Sub
DSW MicroPro 4000 Front Sub
DSW MicroPro 2000 Rear Sub
Samsung c6300 60 inch LED
Sony BDPs370
Room Size 15x30
  • mrloren
    mrloren Posts: 2,473
    The V60 is good or MC60 the V (vanishing) and MC are the same drivers. The extra for the "V" is they look a lot better. RC's are not bad either. The LSI match ones are expensive, Better off for ATMOS just getting V, MC, or RC
  • Slyder01
    Slyder01 Posts: 115
    Thank you
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    PSW 450 Front Sub
    Sony BDPs370
    Room Size 15x30
  • ivanlee13
    ivanlee13 Posts: 34
    edited December 2019
    I'm currently using the 80 F/X-LS to timbre-match with my LSiM speakers as it's the smallest in-ceilings available and only ones that can fit. According to the Polk site, 900-LS, 700-LS and 500-LS also work to timbre-match with the series but those are gigantic and won't fit all ceilings. I originally tried the rc60i but they didn't match well so I exchanged it for the 80F/X-LS.
    Television: LG 65E6P
    Player: Oppo UDP-203 / PS4 Pro / Xbox One X / Apple TV 4K / Chromecast Ultra
    Receiver: Yamaha RX-A3060
    Power Amplifier: Anthem MCA 325
    Front Speakers: Polk Audio LSiM 707
    Center Speaker: Polk Audio LSiM 706c
    Surround Speakers: Polk Audio LSiM 703
    Surround Back Speakers: Polk Audio LSiM 703
    Dolby Atmos Front: Klipsch Reference Premiere RP-140SA
    Dolby Atmos Rear: Pioneer SP-T22A-LR
    Subwoofer: SVS PB-1000
