Recent Polk 705/707 discounts a result of poor design?
Came across a post on audioholics from a speaker designer that the reason for the recent massive discounts of the Polk 705/707 LSiM line is the result of a major design flaw. That is placing two crossovers below 400Hz at 100Hz and 300Hz stressing avr's and requiring large amounts of amplification, possibly leading to component failure. Is it really an engineering feat or is there some truth to this? I'm new to high fi audio so thought I would post this here and some brighter minds can help shine some light on this.
Quoting:
"You need to drop these speakers like a hot potato. The whole design concept is flawed and insane.
Now we have a lunatic who has presented a speaker with not just one crossover below 400 Hz but two. (100 Hz and 300 Hz)
Now I have designed speakers for years. I can tell you that there is no way you can make a safe speaker like that, let alone a decent one, with a passive crossover solution. I say that categorically, there is no way. I have to work with the same laws of nature as Polk. To even consider this, which is a bad idea anyway as the crossover points are too close together, you would need at least three amps with active crossovers.
Inevitably the stress on the receiver or power amp are going to be horrendous with passive crossovers with those specs.
There is a very high probability the crossover is actually in resonance, a very bad situation for amps driving them. However if you cobble together a contraption like that, you will be far too stupid to spot a detail like resonance.
Do not connect your receiver to a speaker like that. It will vastly shorten its life, if it has not already.
The cynic in me leaves to believe that now Polk and Denon Marantz are the same company, they are deliberately trying to boost the market for replacement receivers.
The is the most egregious concept for a speaker I have seen to date."
URL:
https://forums.audioholics.com/forums/threads/need-help-with-polk-lsim-705-and-yamaha-rx-2030.115444/
    F1nut Posts: 52,031
    The tlsguy has no idea what he's talking about, none. Even says they aren't 4 ohm loads when in fact they are. BOZO!!!
  • DaveHo
    DaveHo Posts: 3,583
    I've seen some of the nonsense he's posted over the years, he's an idiot. That said, IMHO the xover freq from MW to the Cassini drivers is too low. I run them full range for music & am always concerned about bottoming out the MW. Enough so that I feel it's holding back what the speaker should be capable of.
  • Emlyn
    Emlyn Posts: 4,839
    edited December 2019
    I would not drive a pair of 707s with a receiver unless it was 4 ohm stable anyway. That would be insane and horrendous at high volume.
    Even if the receiver is stable a high current separate amp is recommended. Those speakers were not designed to be run by lightweights, and neither is the new Legend line. A Parasound A23 handles the LSiM line just fine without any unusual heat buildup, although they sound better with an A21.
    VR3 Posts: 29,556
    Lol...
    msg Posts: 10,479
    Wow, that guy sure is talented with hyperbole. I wonder if he practiced reciting that in the mirror before posting.
  • mrloren
    mrloren Posts: 2,474
    Wow!
    That was a strange read. Polk made the LSiM line for what 9 years? They sold a lot of them over that time, figure there would be many reports on them if they were bad and cooking AVR's.
    One thing I read in that thread is the OP was bi-amping with an AVR, oops. Yeah and wondered why they sounded bad.
    I like my 705's, sound great and have a decent amp powering them.
  • Seriously? Guy’s, AH has a lot of Dealers that hang out on that forum. Most of them won’t even recommend Polk speakers. But yet they’ll surely Chastise anyone that does. There seems to be a hand full that stick together.
    pitdogg2 Posts: 27,376
    Muchieman wrote: »
    I actually find most "dealers" will recommend lines that are more profitable to them.
  • mrloren
    Muchieman wrote: »
    True it is AH after all. Most people there hate Polk for some reason.
    I was reading a thread where this guy was bragging about having over $20k into his system and only spent $200 on interconnects and speaker wire. Gee wonder how it would sound if he spent a few bucks on some AQ or BJC.
    There was this video from Gene where he was saying all anyone needs is Monoprice cable. Then he pulls out a Pair of Kimber cable the run about $900 a pair.
    When we use to have retail stores I'd go in for a listen. Most of the time sales people would bash Polk, I'd ask why. Almost every time I got a blank look.
    To bash the LSiM like this, a line that sold for years is just obnoxious to say the least. I could see if it was a new line but one that has been out for years. Nope that guy got his little bit of compensation for his little under sized body part (brain that is).
  • pitdogg2 wrote: »
    Muchieman wrote: »
    I actually find most "dealers" will recommend lines that is more profitable to them.
    Well said, it is why I posted up. I just find that the person that said Polk's LSiM line on AH forum would say Polk put out a design a FlagShip line with a flawed design. Polk’s LSiM line has a proven record of Excellent reviews with Pro testing not to mention a lot of very happy customers. If my apartment was bigger I’d surely have a pair of the 705’s sitting in my living room.
  • mpitogo
    mpitogo Posts: 520
    I chimed in. Not sure it will help much but someones gotta represent.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • vmaxer
    vmaxer Posts: 5,121
    mpitogo wrote: »
    I had to go read the thread, glad I’m not a member there.
    (That I remember)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • K_M
    K_M Posts: 1,631
    mrloren wrote: »
    Muchieman wrote: »
    Stereophile gave a fairly bad review to the Rta11t's years ago, and was not Sold on the SDA effect at all.
    That may play into it, to some degree.
