Has anyone removed the wood panels on Lsi series speakers?
K_M
Thought we saw some posts few years back about this, but Search was of no use.
Has anyone easily/successfully removed the wood "Extra" panels on an Lsi9 or Lsi15 speaker?
I remember reading it was "Taped" on, but after some minor trying it seemed VERY tightly held on, any ideas?
Vinyl versions are taped, painted versions are glued- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Both our sets are the later Lsi15, with the smooth look on the black, with no seams -
The best way I've found to search the forum is to use a Google search string like this:
lsi wood panels site:forum.polkaudio.com
Just type that into a Google search field.
It says, search the terms lsi, wood, and panels on site forum.polkaudio.com
You can use this format to search any site for content. Place a minus symbol in front of any terms you want to exclude, like this:-term
The above search does seem to return some results relevant to your question.
I disabled signatures. -
