Need help identifying speakers... would like to know the wattage to size an integrated amp
awhicker
awhicker Posts: 2
edited November 2019 in Vintage Speakers
Hi,
I'm posting some photos of my Polk Audio RTE series floor speakers. I wanted to find how much power I needed to properly drive the speakers (I'm assuming it's not extreme). I'd like to upgrade from my old receiver to something nicer like an integrated amplifier. The base is a plastic piece that holds the speaker up a bit for the bass.
I think these speakers are 10 to 15 years old.
PS: I can't find any numbers (model, serial, etc)
  • stangman67
    stangman67 Posts: 2,330
    Look to be the export version of the rt600’s. 50 watts of good power will drive them just fine
    F1nut Posts: 52,258
    Vacuum the cat hair off that poor sub.
  • awhicker
    Thanks much! You da man.
    PS: I have yet to meet a wealthy subwoofer.
    F1nut Posts: 52,258
  • FestYboy
    FestYboy Posts: 3,861
    I love how vague the specs are....
    F1nut Posts: 52,258
    Exquisite Sub: Specifications
    Technical specs
    Type: EXQ-SB-1.2-A
    System: Active subwoofer
    RMS Power: 1000 Watt
    Program power: 2000 Watt
    Frequency range: 16 Hz – 250 Hz
    Maximum SPL: 120 dB
  • Nightfall
    Nightfall Posts: 10,083
    16Hz? Pffff. Skip can hit that in an elevator with a $2 can of beans.
    afterburnt wrote: »
    Village Idiot of Club Polk
