Polk Monitor 10B vs Monitor 11
makaveli6103
makaveli6103 Posts: 33
edited October 2019 in Vintage Speakers
I have been using the 10B's with RDO-194 tweeters for the past few years and recently found a pair of Monitor 11s for really cheap. I hooked them both up to my Pioneer DX-D7000 that allows me to switch between the speakers easily to compare them. I think it has the peerless tweeters as it has the small hole in the middle. Immediately my wife and I noticed the highs are much clearer on the 11s than the 10s and the bass is much more refined compared to the 10s. One area I think the 10s are better are the mids. I am only allowed to keep one pair and currently am leaning towards the 11s. Any other opinions?
    F1nut Posts: 52,141
    The 11's are hands down the better speaker. Polk corrected the inherent comb filter problem of the 10's with the 11's.
  • Nightfall
    Nightfall Posts: 10,083
    Sell them both and get a pair of Peerless RTA-12B's. ;)
    afterburnt wrote: »
    Village Idiot of Club Polk
  • FestYboy
    FestYboy Posts: 3,861
    ::Que the whip crack::
    Come on man, there's always room for another pair (unless you've lost yours ;) )
    J/K
  • boston1450
    boston1450 Posts: 7,758
    I have had both the 10's & 11's. 10's ended up leaving the herd. Really enjoyed them too. I put spikes to them & it really improved the bass quite a bit. Enjoy them gems
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450 wrote: »
    I have wood floors. Any spikes you recommend?
    F1nut Posts: 52,141
    Big ones.
  • boston1450
    If you decide to spike them, you can get disc to put under the spikes. Some come with the disc also. When I did mine I noticed a difference.
    Randy-Maine
    by David WMG
    xschop Posts: 5,655
    How do the X-over components look in the 11's?
    A refresh will definitely clean up the mids in any old Polk set.
  • boston1450
    So did you decide yet ? Just wondering if the Monitor 11 speakers are tagged R&L correctly for you.
    Randy-Maine
    by David WMG
    Selling the 10Bs. But my 11s are not marked L&R. How can I figure that out?
  • boston1450
    Randy-Maine
    by David WMG
  • boston1450
    Im looking for it. I stumbled across it once. My 11's had the L&R stickers on them. They may be stamped on the cup on back. I cant remember. But very important. Maybe someone will chime in. Thx.... here is something interesting too. https://www.polkaudio.co.nz/blogs/reviews-resources/13947939-placing-your-speakers-for-the-best-performance
    Randy-Maine
    by David WMG
  • boston1450
    edited November 2019
    This was a FS post from Jesse. He knows these speakers well. Borrowed pictures
    Randy-Maine
    by David WMG
  • boston1450
    This may confuse you - as it still does for me. There is 2 different Monitor 11 speakers. The speakers you have are Monitor 11's & then there is RTA11 which some also call Monitor 11's. So be aware or this. If not already stated above. I can not find the article I read years back. I will browse again later when I get home. Hope some of this helps
    Randy-Maine
    by David WMG
  • boston1450
    Try pulling your MW woofers. They may be stamped on the label iirc. Worth a try. May be a good time to make sure you have all the "correct" woofers also.
    Randy-Maine
    by David WMG
    Tony M Posts: 11,853
    boston1450 wrote: »
    Great Link!
    That's amazing that Model 11 had mirror pairs. 2 cross-overs in them. :o
    COOL! B)
  • Gardenstater
    Gardenstater Posts: 4,855
    boston1450 wrote: »
    And apparently the RTA 11 is the one that has different low pass frequencies for each of the midbass units and the crossover has 4 inductors, 4 capacitors, and 2 resistors. Even Polk was confused about what to call them each and they mistakenly called at least one of the M11 schematics that are in the forum reference section RTA 11. They also mistakenly label a couple of PCB layout diagrams that are clearly RTA 11, as M11's. :#
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Gardenstater
    edited May 2020
    OK upon further investigation, Polk may have originally been uncertain what to call the RTA 11, having referred to it as M11 on some drawings but they probably settled on RTA 11. This is the one that was vintage 1982 and has the more complicated crossover and was based loosely upon the RTA 12, presumably attempting to correct the lobing issues with the M10 (?). These were in mirror imaged pairs. Then around 1990 they came out with the RTA 11T, which does not have a complicated crossover network and is the tall, deep, narrow design of cabinet, and since they had a vertically linear array of drivers there was no problem with lobing or need for mirror imaged pairs.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    pitdogg2 Posts: 27,543
    IIRC the T after the 11 in RTA11t stood for tower. Then the tl as we all know stood for tri-laminate when the better tweeter came along.
