Hickock 6000 tube tester cleanup
I'm not sure if you've seen pictures of the Hickock 6000 tube tester but they all have that red cloth like cover on them. The glue on mine was coming off and the red cloth was beginning to peel so I dismantled it.
While poking around in it and trying to figure out what the paper wrapped capacitor was it and the red wire came lose from the meter.
A couple of minutes on the web found that I could replace it with a 47uf 16v to 50v cap. Done!
Red stuff was removed, the glue was sanded off and rather than pretty it up I just coated it with a couple of layers of poly. I reglued the top and a couple of the corners.
And it still works!!
Aaron
Enabler Extraordinaire
    pitdogg2 Posts: 27,562
    Good I've some tubes you could test it out with ;);)
  • Mike Reeter
    Mike Reeter Posts: 4,315
    WOW, the Hickock looks brand new. Great job! As the old saying goes 'They don't make 'em like they used to'
  • verb
    verb Posts: 10,176
    Very nice! I've been looking (patiently) around for a tester. Yeah, I took a nose dive down the rabbit hole! :smile:
    msg Posts: 10,535
    Interested in the red cloth if still available.
    SCompRacer Posts: 9,152
    edited October 2019
    Makes me want it back! Nice work Aaron. Nice wood box under that wrap.
    I got that from Brent Jessee.
  • ALL212
    ALL212 Posts: 1,668
    Send 'em! Just don't send 100's...
    verb wrote: »
    Brent Jesse is a good source, not cheap but his have been gone over and calibrated. This damn rabbit hole... :s
    msg wrote: »
    There's always one....always... ;)
    SCompRacer wrote: »
    NO!! Mine...ALL mine!!! :) It has provided many hours of "entertainment". And weeded out what should have been or were advertised as "strong" tubes but proved to be not so strong after all.
    Aaron
    mhardy6647 Posts: 35,377
    IMO (and FWIW), calibration is everything with a Hickok. Not that they're unreliable (they're well designed and well built) but, sans calibration, the numbers they yield are just numbers. When they're properly calibrated, the Hickoks yield numbers that you can take to the bank.
