Replacement Mid Driver for RTi10
mx5miata
Hi everyone, I am trying to replace a blown mid driver on my RTi10. I already called customer support and they do not have any on stock. What are my other options for replacement? I am okay with either a new or used part for it.
Will something from the CSi5 be a direct fit or the newer RTi A series? Aftermarket would be okay but prefer OEM.
Model: RTi10
Mid Driver Part #: RD7217-2, 6.5 inches
Thanks!
Model: RTi10
Thanks!
President of Club Polk -
That's dash 1, not dash 2.Political Correctness'.........defined
Should be a direct fit? Opened up my speakers and it has that same part number.
You're the one that wrote RD7217-2.Political Correctness'.........defined
RD7217-2 was from polk audio support.
