Balanced vs RCA ......
gyosa
Cambridge 851n ....
Going to be connected directly to amp - used as preamp ..
Output voltage twice as high when using balanced outputs vs unbalanced... why ?
So , more voltage to amp , means louder volume balanced vs unbalanced at same “ volume knob” setting ?
I know the amp will still clip at its max input voltage input regardless of cable type used ...
Is there any reason to use balanced if “hum” is not an issue ?
Bk
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
These are the specs for the amp , PS Audio S300 .....
Seems low ... aren’t most amps around 2v ?
Bk
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
Advantage is, a bit better lower noise floor in the signal. Other than that, I can't think of any.HT SYSTEM-
