Mits Tv Color Adjustments?
racer4551
Anyone understand how the color adjustments work on a mitsubishi ws 48-413 tv.It has a standard one button slider control from 0 to 100 and also has a section called perfect color where you can adjust each color individually.My question is this,if was to use the color adjustment section on DVE,and adjust the individual colors with the red,green and blue filters supplied with DVE,you can also adjust the color with the color bar also.You would think if you chose the advanced color adjustment(perfect color) that the single color bar adjustment would be canceled out .So where would you set the single color bar adjustment before you would begin setting the individual color adjustments?Or am i missing something here?P.S. the single bar adjuster sets the color for all the colors with one adjustment.
*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
Post edited by racer4551 on
I'd start by getting a good home theater calibration disk-AVIA is great. Next, set the overall color setting to neutral. Finally, go through the cal procedure with the disc and set the individual saturation levels.
Thats what i am trying to figure out what is the nuetral setting for the overall color adjustment?Its confusing that the color adjustment also has an effect even when you are you using the perfect color setup,in which you can adjust each individual color setting.Right now i am using Digital video essentials and i also have the avia disk.I think i am going to call mitsubishi to find out how this setup works?I have always had kinda weird color settings with this tv,just wish i could find a good isf guy in this area to set it up and forget it.*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
