RTI150-rti38
I forgot, who stacked a pair of rti38 on top of rti150? It could of been rti70 thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I think Sid has some bookshelves stacked on top of his 70s
I stack RT5 on top of RTi70, Silk unplugged.
I have also stacked a RT35i on top of the 70. The RT5 works alot better. Especially with the silk unplugged.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
How did you guys do this? Did you spilt from pre-pro, to ex amp? Or in serires? thanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
dang trey, no offense but the rt5 looks ugly on top the 70's
The rt35's didnt look bad MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Actually the RT5 looks good on top of the RTi70 (to me, in person)
The RT35i matches better.......but it sounds like crap.....
The RT5 is much better in the highs than the RT35i, RTi70, Etc....
So much smoother, calmer, more refined. Woooooooo me LIKE!
I split the signal at the amps.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
See.......they look much better with the grills on.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The point of stacking is to get rid of the weaknesses of your other components.
Obviously, stacking a RTi38 on top of a RTi150 - although adding another tweeter and midbass, wouldnt yield to much of a difference.
The RT35i and RTi70, with both tweeters on sound pretty good. But NOTHING like the RT5 handling the highs and some mids, with the RTi70 midbasses on only. It is just killer.
If you want to stack, I recomend using a DIFFERENT series, as many as you can and find which one you like the best. They all make it sound different, better or worse is up to you to decide on.
I listened with the RT35i on top for a while, then I switched to the RT5 (looks aside), it friggin rocks.
Stacking is easy, turn the bookshelf upside down --- then run preouts to amp, then split the signal......I had as many as 3 splits at one time, when I biamped the RTi70 and powered the RT5.
Pretty simple. Try it out, I recomend it honestly.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
