DIY Speaker spike sliders for hardwwod floors .....
gyosa
gyosa Posts: 770
edited September 2019 in DIY, Mods & Tweaks
Rubber pads are from Home Depot
Magic sliders are from Target
Put ‘em together, they fit perfectly- nice and snug ...
The speaker spikes rest perfectly on the metal washer.
They work perfect - blend in reasonably well with the floor , are rock solid after adjusting spike height - and slide effortlessly when the housekeeper needs to clean !
About 10 bucks total.....
I just couldn’t justify what the Herbies sliders cost ......
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    SCompRacer Posts: 9,121
    Nice and thrifty! Nice speakers too. :)
    My thrifty spike footers were sourced from a VTI audio rack. The end caps were punctured by the shelf spikes from heavy gear over the years. I had ordered new end caps from VTI to replace the punctured ones.
    Using a hole saw, I drilled some 3/8” hardwood inserts. I used construction adhesive to glue them into the VTI end caps. I got some round, heavy-duty adhesive felt feet and applied it to the bottom of the hardwood in the caps. Works great.
