SL-3000 as a replacement to SL-2500?
Hi,
Is the SL-3000 a drop-in replacement of SL-2500?
Monitor 5 Series II
RTA 11T
Best Answer
    pitdogg2 Posts: 27,490
    edited September 2019 Answer ✓
    If you are going to be buying tweeters I'd strongly encourage you to consider the RD-0198's. If you already have a pair of sl3000's laying around then yes you can use them in place of the sl2500 if you have a blown sl2500. You would need to replace both sl2500's with the pair of sl3000.
Answers
  • Thank you.
    Monitor 5 Series II
    RTA 11T
  • boston1450
    boston1450 Posts: 7,758
    When I changed out my rta15tl tweeters with 198's I did one & then listened to it. Shut it off quick & did the other. Wow what a upgrade. Money well spent
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Yeah I hear a lot of good things about RDOs, but prefer not to spend the money now - need to do the roof. There's a guy who has few 3000s (apparently from an SDA uprade); I'm going to buy 2 to replace a dead 2500. If he asks too high a price then I'll consider buying new 198s. Anything to be aware of buying used 3000s? Any fakes floating around?
    Monitor 5 Series II
    RTA 11T
  • No need to take a chance on used tweeters (198's are much better than SL3000's). Total cost for two brand new 198's including delivery is about a hundred bucks. Then sell the old tweeter on eBay and recoup some cash.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Never heard of a fake SL3000, however, they're at least 20 years old by this time.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • boston1450
    Roof is a must :) I had a extra set I gave away here to Sea iirc & if I had extra I'd send em to ya.. stick around a bit & get your post count up & post in WTB section. I'm sure someone can help you. Great bunch of people here
    Randy-Maine
    by David WMG
  • Great bunch indeed. Thank you all again.
    Monitor 5 Series II
    RTA 11T
