Polk DB12 subwoofers
![Systems](https://us.v-cdn.net/5021930/uploads/userpics/442/n2E1QK3X8PYBE.jpg)
Systems
Hey, Recently I purchased a pair of polk db12 subwoofers in a box for $100 dollars CDN off of a friend, and I can't find any information about them on the net. Can anyone give me any info about them?
thanks.
thanks.
Testing
Testing
Testing
Testing
Testing
try in the subwoofer section, 'older models'It's not good, very fundamentally simply not good. - geolemon
i think theyre 300 or 400 watts RMS
SVC 4 ohm
call polk
<<< -- Has these as well....
They are rated about 400W RMS, but perform well at 500Wrms. they peak at 800W or 850, not remember.
as for tech specs, I will look.. I have a specsheet for the model line after mine, but they are relatively the same.....
-Jerry___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
OK here are the specs for the DX series (thats D...X...) series... made after the DB's, but they will have very similar specs:
Driver Complement
Woofer 1 - 12" Diameter (30.48cm)
Polymer Composite Subwoofer
Electrical
Overall Frequency Response 20-200Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 400 w
Power Handling (peak) 800 w
Efficiency 86 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Magnet Weight 40.00 oz.
Install Dimensions
Driver Mounting Depth
Top Mount 5-1/4" (13.34cm)
Bottom Mount 5-3/5" (14.22cm)
Cut-out
Driver Cut-out Diameter 11-1/8" (28.26cm)
Theile/Small Parameters
Recommended Enclosure .88 cubic feet sealed
Resonant Frequency 26.3Hz Hz
Qms 6.71
Qes 0.63
Qts 0.58
Vas 2.80 cu ft. / 79.3L
Cms 213.1 Micro Meters
Bl 13.4 Tesla Meters
Sd .553sq. ft. / 0514sq m
Winding Width 1.0in / 25.4mm
Xmax (linear) .343in / 8.7mm
Xmax (mechanical) 1.0in / 25.4mm
Le 1.5 mH
Mms 172.6 g
Driver Weight 8lbs 3oz / 3.7kg
Vd .062cu. ft.
Other
Product Weight 8.30 lbs.
Speaker Warranty Limited, 1 Year parts and labor
--Jerry___________________________
BTW, I have the manual for the DX subs too, I could never find the one for DB's.. it's in PDF format, ask and I'll e-mail it to you.
Alright thanks a lot for the replies, it was very helpful. I have them hooked up to a gs designs gs4000 amplifier and they sound really nice so far.Testing
Testing
Testing -
Hey folks, i'm going to install two DB12:s to my audi coupTesting
Testing
Testing -
DB12s...just to make sure...youre talking about the old almost all black DBs and not the new ones right?
700mm=27.559"
450mm=17.717"
400mm=15.748"
4.450ft^3 volume to play with
