anyone have a Onkyo TX-DS494 ?
gacole2000
gacole2000 Posts: 255
edited May 2004 in Electronics
U-571 on my system has converted another. My family came over for Mothers Day and now my brother wants me to help him get a starter HT. I will try for some RT 35/25 and a CS 245 to get him started. Use his old Bose 301 for surround until he can get some Polks.
I can pick one of these (Onkyo TX-DS494) up pretty cheap for my brother. Does anyone have any experience with this model? If so, please let me know what you think: good, bad, or otherwise.
Thanks- Greg
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
Post edited by gacole2000 on
  • jefft1314
    jefft1314 Posts: 169
    edited May 2004
    If you can get it for under 200 new, or under 150 slightly used, I'd grab it. Anything more than that seems excessive. You should be able to get a 501 for way under 250 now that it's been replaced.
  • gacole2000
    edited May 2004
    Jeff,
    Have you heard one of these? What were your impressions. I'm looking at $120 shipped.
    Thanks- Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • woodyjacobs
    woodyjacobs Posts: 706
    edited May 2004
    Just picked one up off of ebay for $125 shipped myself for my second room system (which is on it's 6th receiver in two years - I just like to try different receivers). So far I'm pretty impressed with it sonically...it measures up favorably to some of the other units I have run with this system (Klipsch quintet satellites). The remote is kind of crappy, however, and the setup is a bit strange (it requires some front panel work). All in all a good deal for the money though. What I like about it is it has PLII, DD5.1 and DTS5.1 AND has a B speaker switch and a Phono (turntable) Pre...not many other receivers have this without spending a bunch more cash. And so far I think the Phono pre is superior to the Yamahas and Denons that I have owned, for whatever that is worth.
    This thing is not really a powerhouse, however. Rated at 55w/channel (8 ohms) x 5. Okay for smaller rooms but I wouldn't think it would do the job if you like it loud in a medium to biggish room.
    If you think of any specific questions let me know and I'll try to help.
    system 1:
    Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
    system 2:
    XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
    2 channel
    NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
  • jefft1314
    edited May 2004
    I haven't heard it. However, I imagine that considering its specs and the limited reviews I read on it, it should be adequate for a budget home theater, and I can't imagine you even finding a 5.1 receiver for less than 200 dollars, so I'd probably hop on that opportunity
  • woodyjacobs
    edited May 2004
    One more thing...Oinks are notorious for not putting out a lot of bass to the mains when running them in stereo mode. A sub will be a definite necessity.
    Woody
    system 1:
    system 2:
    2 channel
  • Danny Tse
    Danny Tse Posts: 5,206
    edited May 2004
    Actually, there are a lot of choices for 5.1 or 6.1 HT receivers around $200.00.
    Refurbished Denon AVR-1603 can be had for $189.99 at J&R. J&R is a Denon-authorized dealer.
    Both the Sherwood RD-7108 and the RD-8108 can be had for under $200.00. Brand-new.
    J&R even has the new Onkyo SR502 (the latest update of the 494) 6.1 HT receiver with Dolby Pro-Logic IIx for $250.00 shipped.
    And Sears is closing down its audio department, both online and in stores. Check for prices there. I've heard the JVC 7030 can be had for $135.00. This receiver sounds awesome and normally retails for $300.00.
    I am not affiliated with either J&R or Sears.
  • kingtut
    kingtut Posts: 813
    edited May 2004
    double post by accident, so I deleted one of the posts.
  • kingtut
    kingtut Posts: 813
    edited May 2004
    I vote for the Sherwood. My brother had the RD7108, and it sounds pretty nice for the price. It has all discrete channels and very laid back sound. The weak points are: it doesn't have pre-out for all channels for adding amps, nor does it have on screen display; its speakers connections are the spring clip type, not the binding post. The RD7108 only has three A/V connections. I believe the RD8108 has OSD, but not the other functions listed above.
    I have the Sherwood RD7106, which is the older but better version. It has pre-outs connections for all channels, OSD, binding posts speakers connection and 4 a/v inputs. The sound is very smooth and neutral. HomeTheater Mag and Sound and Vision reviewed the 7106 and gave it pretty high marks for a budget receiver. The RD7106 is a 5.1 receiver.
    Search ebay and Audiogon for the Sherwood RD7106. It's a better receiver than the RD7108, although most owners are very happy with this budget receiver, so it's rarely for sale.
  • gacole2000
    edited May 2004
    Great input, thanks. I did not know about Sears. May want to check that out. His den is very small, so I will not need much.
    Thanks again- Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
