FXi50 & f/x500i
What is the difference between these two speakers? From what I can tell there is a difference in weight. Other than that the specs seem like they are the same.
Also what is a good price for a pair of FXi50's that are used and scratched up, but work fine? Your feedback is appreciated!
Thanks,
David
Thanks,
David
Beer on tap is great, until the keg runs dry and the liqour store is closed!:D
The 50 has the silk tweeter, and the 500 has the tri-lam. As for price, look at either Audiogon, or Ebay and you should get a ballpark, but I would guess in the $200 range.There are two ways to argue with women. Both of them are wrong.
Thanks! Now for another dumb question? Which is better the Tri-lam? If so why?Beer on tap is great, until the keg runs dry and the liqour store is closed!:D
No problem. The next question isn't dumb, it is dangerous. Totally depends on who you ask. Best I can do is to say listen for yourself. I know that won't be easy, as they are past product lines, but maybe a fellow polkie has a few laying around near you so you can listen. I personally prefer the silk, but not by a lot. Sorry to be of no help here, but it's all personal preference.There are two ways to argue with women. Both of them are wrong.
Thank you again! I guess I will just have to see what I think since I bought a pair of FXi50's off of Ebay for $147.00 shipped. I allready have a CS400 not the CS400i, and I beleive that is the difference between those 2 speakers. I love the CS400 it actually seems to out power my RT10 mains. I just hope these FXi50's are a good complement to my RT10's and CS400.
Once again thanks for the input.Beer on tap is great, until the keg runs dry and the liqour store is closed!:D -
I exchanged my 55i's with the fxi50 and prefer the fxi for surround duty. I also have a 400 and 400i and like them both. I'll use the 400 for channel 6 in my HT with no worries and the 400i is the front center.
sounds good to me.
1/4twin***WAREMTAE***
