A couple of questions about system set up
ektweety
ektweety Posts: 2
I have the following components:
Polk Audio Speakers TSi400
Polk Audio Subwoofer PSW111
Pioneer VSX-524-K Receiver
SONY CDPCE500 5 disc changer
The subwoofer when plugged in will have a very low hum, even if it's not connected to the receiver. I also just want a rundown on what would be the best way to connect the speakers so that I can make sure I have it all at least set up right. I don't use this as a home theater system, its strictly for music.
  • FestYboy
    FestYboy Posts: 3,861
    The hum is a ground loop, try a ground isolation plug in either the sub or receiver. But better yet, dump the receiver and step into a dedicated 2 channel unit. It will suit your use much better.
  • ektweety
    I will definately look into that, but that is what I have right now. I just realized that the subwoofer is not working at all...no output whatsoever...so I may have more of a problem then I originally thought.
    F1nut Posts: 52,200
    The plate amp is bad. Time for a new sub.
