Subwoofer cable question
MarkPana
MarkPana Posts: 4
Ok guys happy to be here.
First question:
I am current running an Audioquest HawkEye as my subwoofer cable and truly love it. But i have always want to try the Audioquest Sub-3 or the Newer Husky. I have a Sub-1 and i like the HawkEye, bass seems tighter and more musical with less overhang. Sure that is do that Audioquest wonder PSS conductors vs. The 2.5% silver plated copper of the Sub-1 as my VDM-5 (also PPS) had about the same advantage over the Sub-1 just not as much as the HawkEye.
The Sub-3 have DBS as the Hawkeye and using 21awg 6.1% silver plated copper conductors vs the HawkEye 24awg PSS (Perfect Surface Silver).
I finally found a deal on a Sub-3 and wondering if i would be going backwards.
Thanks for all the help in advance.
  • sgmsmg
    sgmsmg Posts: 556
    Isn’t the HawkEye a digital cable? Designed for passing a digital signal as opposed to the Sub-3 which is design for an analog signal. Not sure what difference they will actually have but...
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    F1nut Posts: 52,052
    Yep!
  • From my understanding it has no bearing on the signal. The Hawk is a 75Ω coax cable which a lot of High End DIY IC are and even more so High End factory IC are. So it being list as ditigal cable doesn't effect the signal transfer.
