Issue with Epson 8700UB Projector?
I seem to recall years ago there used to be a dedicated "Home Theater" forum, so if this isn't the appropriate place for this post I apologize!
tl;dr - How long should I expect the fan on my Epson 8700UB to stay on after I turn off the projector? Also, bulb replacement recommendations?
I used a Runco CL420 for a number of years previously, and when I shut it off the fan would always stay on to cool the bulb for several minutes. When I upgraded to my Epson 8700UB, I was very surprised to notice the fan only stayed on maybe a max of 30 seconds, possibly not even that long. But it performed fine, so I was happy. Then one day the bulb exploded. The bulb is rated for 4000 hours, and it had much less than that on it. Since I apparently did not note the hours anywhere, I'll just say it was less than 2,000, but I really think it was a good bit less than that as well.
The shorter fan duration and the bulb failing earlier than expected has me concerned there may be a problem with my specific projector, but also it was a used projector with a (probably) quite old bulb in it, even if the hours were low. So I can definitely accept this being a fluke and not an issue with the projector. I just don't want to spend the money ona new bulb only to have it blow soon as well.
ALSO, what about bulb replacement options? New from Epson a ELPLP49/V13H010L49 bulb is $331. I'd much rather spend lessthan that. Googling I see what are assuredly non-OEM replacements for ~$60, as well as replacements that claim to be OEM with an Osram bulb for ~$130-160 and carry 90-180 day warranties.
Thank you for any feedback you can provide!!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
    pitdogg2 Posts: 27,543
    Forget the non OEM bulb. they're not worth the hassle for the problems I've been there done that with a rear projection TV and it was a real pain in the rear. I used bulb solutions local to me they have OEM stuff you may have to put the bulb in the cage I don't know how your projector is that there may be some work on your end involved.
    https://www.bulbsolutions.com/
  • audiobliss
    audiobliss Posts: 12,518
    Thank you for the advice! I've found some Osram and Ushio replacement bulbs I'm currently debating between.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    Remember if you get the naked bulb and you have to put it in your cage wear latex gloves to not touch the bulb.
  • audiobliss
    Thanks for the reminder! I regret it now, but when bulb blew I threw out the cage as well, so I'll have to buy a whole new assembly. I'll not make that mistake again next time.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    audiobliss wrote: »
    Oh man :'( that can be costly. Prepare yourself
