Road Trip - Polk SDA SRS 3.1TL Black
Looking awesome!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Looks fantastic!!!
Crossover Pic
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sweet!Remember, when you're running from something, you're running to something...-me
Wow! Awesome. I don't think I realized how big the 3.1TLs are. Beautiful.I disabled signatures.
Those look fantastic
The SDA Interconnect Trey makes is superb.
Those new neutrik nl4 connectors are much better than the old ones- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Better connectors and a much much better seal inside.
They also made the numbers way easier to see- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I would say they fit tighter as well..
Forgot to mention the contacts are copper versus brass like the old ones- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Update, been burning in for weeks. That little magic box is amazing. Moved them to another wall for much improved sound.
Awesome!
Good looking setup and the dreadnought is a nice little performance boost for sure- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
