Best solution
AJvW
AJvW Posts: 3
Hi guys
I,m new to this. I am currently in a dilema. I am running a
Onkyo TX-NR 3009
Polk Audio A9s Fronts
Polk Audio CSi6
Sony dual firing sub.
I am looking to get more out of my A9"s. I have been given few ideas but not sure.
Power amp Rotel RB1552mkii , Emotiv XPA 2 and a marantz mm7025.
The music i mostly listen to is jazz (vocal and instrumental) and R&B
Help
  • Nightfall
    Nightfall Posts: 10,083
    Marantz
    afterburnt wrote: »
    Village Idiot of Club Polk
    pitdogg2 Posts: 27,168
    edited July 2019
    Out of those I'd pick the marantz as well. That being said I personally feel it is going to be the same as what you have and a sideways move. If you're going to invest in an amp get more power and current. Those speakers need high current and power.
  • mrloren
    mrloren Posts: 2,473
    The Emo has power but might brighten up the A9's too much. The Marantz is a step up from the AVR, don't know if it will give the A9's the juice they need.
    I'd look for a used Parasound for the A9's
  • AJvW
    AJvW Posts: 3
    What would you suggest based on your comment on more power and current
  • mrloren
    The RTi line likes power and lots of it. To make A9 sound their best a good Parasound amp would do the trick. I'd even look at Outlaw Audio or Monoprice ATI amps. I had RTi8 and a big Sony ES avr, They sounded ok on music and great on movies. One weekend I got to demo an XPA 2 Gen 1 oh did they ever come alive.
  • AJvW
    AJvW Posts: 3
    Hi Mrloren
    I have looked for the parasound but no luck as yet. I live in South Africa so it is a bit difficult to purchase from the USA.
    AJvW wrote: »
    Hi Mrloren
    Well then my Parasound comment is no good as well. I do not know what South Africa has available or what voltage you guys run down there.
