Polk Rti8 speakers with Harman/Kardon AVR130
hmalekib
hmalekib Posts: 1
edited May 2004 in Speakers
I just bought the Polkaudio RTi8 to use with my Harman/Kardon AVR130 reciver. What do you guys think about that setup??? Also I didnt really know I have to work in the speakers so I kind of started listening to music at high volumes.. how bad is that for the speakers??
  • Early B.
    Early B. Posts: 7,900
    edited May 2004
    I hope you're not playing your system too loudly because your receiver is a bit underpowered for the 8's at high volumes. In fact, your speakers will sound much better if they were given more juice.
    "God grooves with tubes."
  • Ceruleance
    Ceruleance Posts: 991
    edited May 2004
    The H/K 130 will be fine and you didn't do any damage to your speakers, it's an all or nothing kind of thing. However, it's possible that you could fry them if you play them too loud so keep it reasonable.
  • WJE
    WJE Posts: 27
    edited May 2004
    By "high" volumes, what is the setting of your volume? Are you still in the negative numbers, or have you hit "0" and are running it in the positive numbers?
    I thought the H/K receivers can pretty much play un-distorted until the volume level runs out (+15 or so from what I recall.)
  • Ceruleance
    edited May 2004
    I would not go past 0. just because there is a 10 on old integrateds doesn't mean it can handle that load.
