Bi Amp with Amp?
Does/ can one use a two channel amp to bi-amp a single speaker? Or is that over kill? Or even possible?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
    txcoastal1 Posts: 13,514
    You can use 2 of the same amps and do a horizontal or I prefer a vertical bi-amp. You must remove the jumpers on the speakers.
    This will obviously increase your head room, and requires 2 sets of speaker cables per amp/speaker
    Do not use 2 different amps unless you want to go completely passive and disconnect the crossovers ...whole different ball game
  • joecoulson
    joecoulson Posts: 4,943
    Waste of time. If the amps are capable of running bridged, do that to each speaker with quality jumpers. Thank me later.
