Full Set Of Rings CRS/Monitor 10’s
Toolfan66
Toolfan66 Posts: 18,412
edited July 2019 in For Sale (FS) Classifieds
I have a full set of rings that will fit CRS+/Monitor 10’s they will fit the 7’s as well you will just have a couple driver rings left over..
I had a set of 10A’s I was going to upgrade, and decided they sat around too long, so I let them go..
Keep in mind when I do an upgrade I use longer hardware and trim it down just below the wood surface, and the 10A’s the drivers and passives are not recessed like the later models,
SO THE HARDWARE WILL NEED TO BE TRIMMED FOR YOUR PROJECT!!
A little hand held grinder or bench grinder works great..
So what you get is below:
Tweeter Brackets
Driver Rings
Passive Rings
Binding Post Rings
All are Powder Coated Black (yes I found black paint)
I cannot find the BHCS I had for these, I will continue to look but you might have to source your own..
