Best In-Ceiling speakers for Atmos
Hi guys,
Currently running a pair of LSiM707s, 706, 4x 703s with 4 upfiring atmos speakers (klipsch and pioneer) for a 7.1.4 set up. Looking to upgrade a pair of the atmos up-firing speakers to in-ceiling speakers instead and ideally want it to match with my LSiMs. What would you guys recommend? It looks like 80 F/X-LS, 900-LS, 700-LS and 500-LS are all timbre-matches. Does a specific one work better as atmos speaker? Would love everyone's input, thanks in advance!
Television: LG 65E6P
Player: Oppo UDP-203 / PS4 Pro / Xbox One X / Apple TV 4K / Chromecast Ultra
Receiver: Yamaha RX-A3060
Power Amplifier: Anthem MCA 325
Front Speakers: Polk Audio LSiM 707
Center Speaker: Polk Audio LSiM 706c
Surround Speakers: Polk Audio LSiM 703
Surround Back Speakers: Polk Audio LSiM 703
Dolby Atmos Front: Klipsch Reference Premiere RP-140SA
Dolby Atmos Rear: Pioneer SP-T22A-LR
Subwoofer: SVS PB-1000
  • mrloren
    mrloren Posts: 2,474
    Any of those will work fine.
    I went from MC80 to 80F/X RT. Difference is the F/X seem to spread out the sound more as in less local sound
  • ivanlee13
    ivanlee13 Posts: 34
    Thanks for the feedback! I've went ahead and ordered the cheapest pair I could find online (Polk 700-LS). Very excited to have these set up to finally get some sound really coming from above.
  • mrloren
    ivanlee13 wrote: »
    Good call.
    I tried the bounce speakers and the elevation ones on the bedroom HT both sounded no where close to the in ceiling speakers.
  • ivanlee13
    ivanlee13 Posts: 34
    mrloren wrote: »
    ivanlee13 wrote: »
    Good call.
    Hey mrloren! I had an installer come in and cut up my ceiling. We realize the 700-LS is way too deep for my ceiling as there is a water pipe less than a feet up. However, the 80F/X-LS should fit nicely in there. I'm looking at the manual for the 80F/X-LS and notice there's a button to choose "Solid" or "Diffuse", which one would you say is best for using as Atmos? Would it be solid, since I have the back upfiring speakers still or should it still be a "diffuse" effect since they're used for atmos? Please let me know what you think, thanks!
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Use the "Solid" setting for Atmos.
  • ivanlee13
    ivanlee13 Posts: 34
    mdaudioguy wrote: »
    Thanks for the quick help!
  • mrloren
    My 80F/X RT do not have that switch. mine are RTI series while the LSI series has the solid/defuse switch.
  • ivanlee13
    ivanlee13 Posts: 34
    mrloren wrote: »
    I just realized that, thanks for responding! I'll use the "solid" setting as per mdaudioguy's guidance :smile:
  • mrloren
    ivanlee13 wrote: »
    mrloren wrote: »
    The grill's come off easy. try them both
