Help ISSUES with one of the speakers POLK RTI A7s
daoki
daoki Posts: 32
edited June 2019 in Speakers
Hey guys, I’m pretty new to the forum. So any advice is helpful and much appreciated. I have a pair of Polk audio RTI a7s running together with a Yamaha PC2002M power amp and Yamaha c2x preamp. Been using this setup for the past 6 months everything working fine. Just recently moved house had the speakers on the truck tied down firmly and covered up properly. Moved into the new house setup my speakers and unfortunately one of the speakers has lost its mid range and tweeter sounds. The other speaker is working fine no issues. I thought it was possibly a issue with the power amp so I switched the speakers around checked all wiring setup to pre amp as well but still the same issue with the one speaker not producing any sound from the mid range and tweeter the two sub woofer drivers on the speaker are producing sound and working. There was no physical damage on the front grill and the actual drivers themself or around the outside of the speakers. Is it possible something could of been knocked inside and come loose? And is it a easy fix? Possible taking out the mid range and tweeter driver to inspect or solder any loose wires? Any help would be much appreciated, so shattered can’t even listen to my babies in my new house. ;( :(:(
  • BlueFox
    BlueFox Posts: 15,250
    So?
    VR3 Posts: 29,631
    Welcome
  • daoki
    daoki Posts: 32
    Sorry guys I just updated the thread
    F1nut Posts: 52,164
    A few wires probably fell off. Pull the non-working ones to check.
  • BlueFox
    daoki wrote: »
    Makes more sense now that there is more than the first sentence.
  • daoki
    daoki Posts: 32
    I haven’t actually started taking any of the unresponsive drivers out yet but once I do and if they have fallen off as you mentioned are they as easy as just connecting them again or would solder work be needed ? And would I be able to clearly see where they would be connected. I’m a Noob when it comes to this stuff. I just don’t want to take them out and then look inside to a maze of wires but I’m hoping there easy to connect again.
    Cheers
    Clipdat Posts: 13,101
    edited June 2019
    No solder needed. The wires use spade connectors that slide right on to the terminals on the rear of the drivers:
    If you find one that's come undone, just slide them back on to the correct polarity spade and reinstall the driver.
  • daoki
    daoki Posts: 32
    Thanks man. I’m assuming this would be the same for the tweeter as well yeah ?
    Yes, I'm fairly certain they have the same style connectors.
    F1nut Posts: 52,164
    All are connected with Fastons and will slide back on. The + and - are different sizes so you can't screw it up.
  • DaveHo
    DaveHo Posts: 3,583
    Before you open it up, have you confirmed the binding post straps are still in place?
  • daoki
    daoki Posts: 32
    Cheers guys problem solved was just as easy as sliding the fastons back on. Thanks. Enjoying them right now as I sip on a glass of cognac. ;)
  • verb
    verb Posts: 10,176
    daoki wrote: »
    Great job! Nothing like popping the hood, and finding out that it's a simple fix! Well done! And to the CP members in their usual fashion helping out! :smile:
