No not the Hitmaster, sob
I bought two Hitmasters when they were on sale at Walmart for $20 each. Really amazing little self contained speakers. I gave one to my son and the other has been my companion with a bluetooth receiver stuck to the side. Recently the sound quality took a dump. I opened it up to find one of the small caps had gone bad burning up a bit of the circuit board in the process. I fear its a goner. I could probably rebuild that part of the board but feel I should cut my losses and find a replacement.
I just feel sad.
I just feel sad.
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808
Sounds like you got WAY more than you money's worth!
RIP hitmaster...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
The issue of the heat generated by active components in powered loudspeakers self-immolating is an old one -- and a pervasive one.
Better $20 speakers than $2000 ones (lookin' at you KEF)
Yup, gonna stick it on the ultra low priority project shelf. Maybe after I have found a replacement and am satisfied, I will send it on to dead speaker heaven. Bought them January 2011. Got a good 8 years out of this one and the other is used daily by my Son. Can't complain. Just hate it when something you use often gives up.
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
Love my Hitmaster. Use it all the time for yard work, camping etc. Still running strong (knock on wood)
There are some surface mount capacitors on the back side that look charred. It looks a bit more that just a cap swap.
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
So I had to look it up! Looks cool! 20 bucks? Sounds like a deal! At that price, no harm in trying to fix it, IMO!
I have a Polk Camden Square that I use in the garage, from Sam's Club a while back. No where near the 20 dollar deal you got! Keep us posted!
