NOVA Retirement Sale - Pr. Behringer B212XL Speakers - $210
Nhpm510
Behringer Eurolive B212XL 800-Watt 2-Way PA Speaker System
2 like new B212XLs in the original boxes used for a temporary home theater set up. $210 for both.
Built to go on the road.
From the manufacturer:
High-power 2-way PA sound reinforcement speaker system for live and playback applications (200 Watts Continuous / 800 Watts Peak Power)
Ultra-compact and lightweight system delivers excellent sound even at extreme sound pressure levels
Extremely powerful 12'' long-excursion driver provides incredibly deep bass and acoustic power
State-of-the-art 1.75'' titanium-diaphragm compression driver for exceptional high-frequency reproduction
Ultra-wide dispersion, large-format exponential horn
Overload-protection circuitry ensures optimal HF driver protection
Versatile trapezoidal enclosure design allows different positioning:
- Stand mounting with 35-mm pole socket
- Tilts on its side for use as a floor monitor
Ergonomically shaped handles for easy carrying and setup
2 professional speaker connectors plus ¼'' jack connectors
High-quality components and exceptionally rugged construction ensure long life
Conceived and designed by BEHRINGER Germany
Even Better Than Before
These loudspeakers take everything musicians love about the original B212 loudspeakers and upgrade them with the same bass and treble/mid transducers found in our wildly popular B212A passive version for even better sound and power handling. And with integrated overload protection circuitry, they arrive ready to push it to the limit without putting their high or low frequency drivers in danger.
Triumphant Transducers
Every stitch of these loudspeakers is built to deliver, but the fact is that their transducers (woofers and tweeters) are the only part you actually hear. While some manufacturers are okay with putting off-the-shelf transducers in their boxes, we custom-design and build ours from scratch. Not only do we wind our own voice coils, we grow the trees that are processed into the paper pulp that becomes the cones. We even machine the frames and backplates. BEHRINGER's quality is truly under control.
Big Sound, Lightweight, Low Price
Big here, small there, lots of this, light on that - everyone's got their preferences, but the EUROLIVE B212XL has proportions we can all agree upon. These loudspeakers pack a clean, punchy wallop (and can handle up to 800 Watts), they are easy to lift by their recessed handles (24 lbs) and are available at insanely low prices. Who wouldn't want to hook up with one of these beauties?
Get on the Stick...or Get on Down
The B212XL is perfect either as part of a PA system or as an onstage monitor. If the situation calls for a PA, mount the speakers on stands via the 35mm pole socket. From there, send a line from the MAIN OUT of a mixer (such as a XENYX 1202FX) to a power amplifier (like the EUROPOWER EP1500). Finally, attach a B212XL to each of the amp's outputs. These loudspeakers have inputs for both professional speaker cable and ¼" cable. Because they have two parallel inputs, you can connect up to two of them to any channel on a power amp. But these loudspeakers don't have to be confined to an upright position. Just lay them on their sides for use as a floor monitor. You'll find that they tilt to the ideal angle for onstage monitor wedge applications.
They also make swiveling wall-mount brackets for the B212XL.
For more pics - info
https://www.sweetwater.com/store/detail/B212XL--behringer-eurolive-b212xl-800w-12-inch-passive-speaker
Update - now adding in a HT JBL 8" sub and you get all three for $200!!!
Passive speakers, like the 212s, need to be connected to a receiver or amp just like your good ol' Polks.
Post edited by Nhpm510 on -
Would make a great outdoor DJ rig for me, too bad I'm not local.
are you including the connector cables from amp to receiver?
Anyone coming up from @Nhpm510 to the north in the next week or two?
I am in Springfiel, VA
Sounds like one heck of a deal you're offering.
I'm really shocked at this spec. though.
Maximum Peak SPL:
95dB
This is loud but shouldn't they play louder?Most people just listen to music and watch movies. I EXPERIENCE them.
Maximum Peak SPL:
95dB
It would've been sold already, but I'm too far and won't be down that week until after he's gone. Even then I'm not sure the would fit in the car with everything else I'd be bringing back.
pm'd
Please buy them and remove my temptation! lol
I'm trying to make it work out. There is a questions if the wiring can be made in near 50' lengths. I know he was moving soon, so that may be a thing but I'll wait. -
Anyone heard back from him?
Looks like he was last active on June 23rd.
That was around the time he said he was moving. thx.
