hidden sub and quality of sound
Hap
Hap Posts: 10
I am getting LSi25s for mains and want to move my sub behind me. The only spot that meets with WAF is under an end table next to a sofa.
My question is will the sound be impacted negatively. Has anyone really hidden their sub without any sound problems. Will there be a muffled factor. Thanks Henry
Post edited by Hap on
  • Tour2ma
    Tour2ma Posts: 10,177
    edited May 2004
    First, welcome to the Club...
    With the 25's I'd expect you are crossing over to the sub at a fairly low frequency, 80 Hz or less. Down there I'd expect losses will be minimal as deep bass is very hard to kill.
    The sub's relationship with your room and your listening position will have more impact on its performance than being "hidden".
    More later,
    Tour...
    Vox Copuli
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited May 2004
    Recommend the LSi15 and the best sub you can afford instead. An 80 Hz xo is perfect for movies, and for music only you can go even lower. I wouldn't go below 50 Hz with the 15's, regardless.
    SVS
